7 members (Hotrod Lincoln, 1955 1 Series, TexasA&M48Truck, CandoBrent, Forty9, TUTS 59, MikeStone1953),
140
Mod | | | Forums66 Topics128,106 Posts1,056,211 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2007 Posts: 38 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2007 Posts: 38 | any ideas? need all the help I can get. want to keep truck as original as possible, thanks | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | there was a power steering option available back then [RPO 350 in the assembly manual, called "hydraulic steering] - the pump was on the back of the generator, seen one or 2 on e-bay - the "power" was a piston on the drag link
other than that, you'd hafta do some fancy work to adapt a later steering box to the original column, but it wouldn't be anything like original down below
Bill | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | There are kits out there to adapt the steering gear from a 67 up. I know Classic parts has them & some other suppliers too. The brackets to put the pump on a 6 cyl. will probably have to be fabricated. I don,t think the pump behind the gen. will work on a six. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | I'm not sure if they're still available, but you used to be able to get the original type power assist from Golden State and Brother's. I recall it was somewhat pricey ($700) the last time I checked. It also required that you adapt a later style pump and make your own hoses to hook up the pump.
Bill Burmeister | | | | | Joined: Apr 2005 Posts: 2,098 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,098 | The after market unit that Bill referred to is still around but they are expensive and not very good. They are fine for low speeds and parking lots but don't give you a good feel of the road in regular driving. Almost dangerous. I did everything possible to make the one I had perform right, reduced pump pressure, replacement tie rods, tire pressure, alignment, rebuilt the control valve, and others. I ended up replacing it with a Toyota PS box. It's not an easy conversion, but worth it. Fred
| | | | | Joined: Sep 2006 Posts: 1,997 Big Bolt Forum Co-moderator | | Big Bolt Forum Co-moderator Joined: Sep 2006 Posts: 1,997 | Apachetrucks, wow that looks impressive. Those parts all look new except the pulley and generator. Are they? A day without laughter is a day wasted- Charlie Chaplin When wrestling a grizzly bear, you have to keep at it until the bear gets tired, not when you get tired. 1948 Chevy 2-Ton | | | | | Joined: Feb 2005 Posts: 199 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2005 Posts: 199 | No new parts,just a lot of work restoring them.
I am working on the generator/pump now and will post the results in my webshots shoebox when I finish with it.
The key to getting the correct pump pressure is the harmonic balance wheel must be double groved so the pump has a separate belt.Got mine from a fellow Stovebolter.
I have this same set up on my 57 Belair (283 V8) and except for the occasional leak I have had zero problems. Hobert
"The Lord is my shepherd"
| | | | | Joined: Jan 2007 Posts: 38 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2007 Posts: 38 | aPACHETRUCKS, do you happen to have another one of thise "kits", I assume everything bolts up, what modifications are needed? thanks marlo | | | | | Joined: Apr 2005 Posts: 2,098 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,098 | Hobert, The parts in your picture look great but appear to be from a 60's truck. The task force trucks had the shaft & tube integral to the steering box. This system works great on cars & trucks with A-arm suspension but in my opinion not so good on straight axle trucks. mjv, One thing to remember is that any "power assist" like the one shown is dependent on a good steering box. Something to think about when working on 50 year old vehicles. Fred
| | | | | Joined: Jan 2007 Posts: 38 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2007 Posts: 38 | rfs56, if so, would that power assist option that is offered from CPP a good one, its runs 900, plus I need a pump and a bracket, I dont know where else to go. Was wondering what was the best affordable option. | | | | | Joined: Apr 2005 Posts: 2,098 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,098 | Marlo, As I mentioned in my previous post, I had one, I purchased the complete unit at the swap meet for $100 and it was nearly new. I guess the previous owner got rid of it because he could not get it to work right. I was certainly not happy with it. There are not many options and still maintain everything stock. I just installed a rebuilt steering box in a 57 Cameo and it was a vast improvement. If you use the stock steering box and the skinny tires they steer relatively well but not as good as an upgraded power steering. I have a stock looking truck but I upgraded to disc brakes and power steering for my safety and convenience. Most people that look at it don't know the difference anyway. Fred
| | | | | Joined: Feb 2000 Posts: 769 Shop Shark | | Shop Shark Joined: Feb 2000 Posts: 769 | Check out CPP. I saw in a mag. that they now have a Toyota conversion kit. I did not see a picture of it on the web site, but they do list a Toyota box under Toyota power steering conversion kit. Here is the link. http://www.classicperform.com/4754chevtrk.html | | |
