3 members (2-Ton, 1955 1 Series, Phak1), 126 guests, and 2 robots.
Topics128,091
Posts1,056,449
Members48,443
Pulled the heater from the '58. Sent the core out and had new core soldered in. Going to reinstall this week. Will be great to have heat in the 'ol girl... Question, what is the best lube for the cables?? I have rebuilt the deluxe controls and want to do everything possible NOT to break another lever.. (seems like someone would make replacements that are not potmetal). Tempted to mill some out of steel stock... Anyway, what it the best lube?? thanks in advance
Carl
'58 3600 350/4-sp/stepside/big window cab
'59 3100 235/4-sp/stepside
For my '62 heater cable, first I hosed the whole thing down with brake cleaner. REALLY hosed it down. Then I shot it with WD40 and let that soak the wire.
Then hit it again with brake cleaner to remove the WD40.
Then I used simple white lithium grease on the heater cable. Put it on the exposed ends, and worked it back and forth by hand. A LOT.
Also bead blasted the entire duct work, which got rid of a lot of grime around the door, etc. Painted it all and put it back together. Works like a brand new unit.
Brad
SOUTHERN FALL GABfest
October 6 ~ Commerce, Georgia
Details here!
Never Pee on an Electric Fence.
While were on cables.How do I keep my throttle cable from being sucked back in after I have set it at the speed I want on the road? Do you put a slight bend in the shaft at the dash? I wish I had a friction lock like on air planes.
Lubing control cables is a touchy subject. If you use an oil, dirt is attracted and it will gum up, making it hard to work. And the cable housing becomes a mess. But it does help keep the cable from rusting.
The other school believes that graphite powder is the lube to use. It doesn't attract dirt and does a good job of lubing the cable. But graphite doesn't protect against rust.
This is where I go to my gun cleaning supplies. Remington Drilube is a teflon based lubricant that dries on the surface and protects against rust without the mess of graphite. You can buy it at most gun shops, including some Wal-Marts.
Fred
52 3600
69 C-10
Hey Beaver, I don't think the intent of the throttle cable was cruise control. It is meant for use when starting cold. I don't think I would put any bends in it. I also don't think I would use it as cruise since it doesn't disengage with the brake.... eek
When I yield to Him, it's amazing how peaceful and enjoyable life is meant to be.
1947 Chevy COE
I also think one of the major uses intended for the throttle control was for using a PTO, but not a cruise control.
1950 Chevy 3100
261, 4 speed
Purchased 1977
1964 Pontiac Lemans Convert
Anyone ever try motorcycle chain wax? Deep penetrating, but dried with a harder less sticky surface to prevent dirt accumilation.
Just a thought anyway, I may try it myself when I get to that point.
1956 GMC 370 dump " 'Tater "
1970 VW Volksrod "the Black Bomber"
2007 Chevy Avalanche
2020 Jeep Cherokee Trailhawk,
2005 Harley Davidson FLHTCUI
I dig all cars, old and new, whether they were hammered out of American iron, German steel, or Japanese tin cans. Being unable to appreciate them all is missing out on a world of great things.
But thats just MY opinion!
:P
I have used PJ1 motorcycle chain lube. Ditto on the WD40 for cleaning & working them loose. Brian
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
I've had good luck with auto trans fluid.take the cable off and dunk it in a pan of the stuff and let it soak.Yes it's messy,clean the outside off and your good to go
Junior Member
Junior Member
I have to agree with Fred T, though I'm not much of a shot. My other Stovebolt is a mountain bike and I've found many uses for the teflon based lubricants popular with two wheelers. Works like a charm on all cables and very inexpensive.
I wouldn't recommend drugs, alcohol, and violence to anyone...but they've worked well for me.
