1 members (Hotrod Lincoln), 88 guests, and 5 robots.
Topics128,014
Posts1,055,325
Members48,419
#223298 01/03/2007 1:14 AM
Big day tomorrow I will be putting my windshield in tomorrow. Are there any tips on putting it in. I have to set it in the frame and then put it on the truck. I have read all the tech tips but I wanted to make sure I don't miss anything. It's a 42 1/2 ton with(I'm so excited) a crank out windshield. I can't wait.
The crew that works on the \'42 --Sara, Hannah and Abby
#223299 01/03/2007 1:19 AM
Z
Z Offline
Do you have window tape? Mine went back in much easier than I thought and with the new rubber it worked out well. Get someone very flexible and young to lay on the floor of the truck to hook up the crank for you under the dash. I have to get a new crank because mine is stripped but I put it in just to get things moving.
Good luck and let us know how you make out.
1946 Chevy Pickip
#223300 01/05/2007 2:02 AM
I put the windshield in it doesn't fit right. There is a gap at the bottom corners - way less than a 1/4 inch and going up the sides. It seems like the frame needs to be at more of an angle as it is very tight in the middle bottom. I'm wondering if I should bend the frame(with the glass in). Any ideas?
#223301 01/05/2007 2:28 AM
Z
Z Offline
What are you using for the inserts in the frame to bolt the two sides together? I was a little worried about the ones I bought from ACT after hearing people say they needed to bend them because they did not fit right. I put my frame together sans glass first to make sure it fit well and set it on the truck in case I had to bend it. I do not think I would try bending it with the glass in just in case.
A stupid question? You do have your windshield rubber attached to the frame right?
1946 Chevy Pickip
#223302 01/05/2007 1:55 PM
This is an orig frame out of a 41 with the orig inserts to bolt them together. Yes I should have pre fitted it before I put the glass in. Not a stupid question - I do have the rubber on the frame. I just don't want to take it all apart but I may have to.
