5 members (2-Ton, rfs56trk, Hotrod Lincoln, carbking, Otto Skorzeny), 92 guests, and 1 robot.
Topics128,260
Posts1,058,311
Members48,485
#223241 01/02/2007 4:15 PM
Junior Member
Junior Member
59' 1/2 ton...While installing my new aftermarket wheels, I noticed the 3 rivits on the mounting surface. These rivits wont let the new wheels set flat against the hub...(the original wheels recede in these rivited areas)... can and should these be ground down?
I'm concerned with this because I put on about 40 miles yesterday stopping every 5-10 to retighten the lugs. They didnt start staying tight till about the end of the trip...
#223242 01/02/2007 4:50 PM
wellll, GM put'em there, and went to the trouble of designing wheels to suit .....
maybe you can grind notches in the new wheels? grin
it is necessary to cut those rivets to replace a drum, without a way to replace the rivets, so I'd say it'll work if you make sure no bits wind up inside
#223243 01/02/2007 11:19 PM
Riding in the Passing Lane
You can grind them down or wack em off. The lug nuts hold the drum on tight. Don,t ruin those wheels.
1972 Chevy c10 Cheyenne Super
#223244 01/02/2007 11:31 PM
I agree with red and wrenchbender. Cut the rivetts off. The wheel has to be flush with the mounting surface to be seated properly. Also, if you have access to a torque wrench, tighten the lug nuts up with that for the final tightenign. About 65 ft/lbs shoud do with the stock studs on a 1/2 ton.
Bill Burmeister
#223245 01/04/2007 3:27 PM
I don't have this arrangement on my 1 Ton so I am curious as to the function of these rivets. Why are they there?
1951 1 Ton Completed
#223246 01/04/2007 3:50 PM
Junior Member
Junior Member
I think I read somewhere that the hub and drum was riveted together to elimanate a task in the assembly line....????
#223247 01/04/2007 10:40 PM
Better yet lets just drill them completely out counetrsink the hole and install countersunk rivits. We do it all the time here at Lockheed where I have been working for the last 35 years. :p
