| | | Forums66 Topics128,095 Posts1,056,078 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2006 Posts: 42 Junior Member | | Junior Member Joined: Sep 2006 Posts: 42 | 59' 1/2 ton...While installing my new aftermarket wheels, I noticed the 3 rivits on the mounting surface. These rivits wont let the new wheels set flat against the hub...(the original wheels recede in these rivited areas)... can and should these be ground down?
I'm concerned with this because I put on about 40 miles yesterday stopping every 5-10 to retighten the lugs. They didnt start staying tight till about the end of the trip... | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | wellll, GM put'em there, and went to the trouble of designing wheels to suit ..... maybe you can grind notches in the new wheels? it is necessary to cut those rivets to replace a drum, without a way to replace the rivets, so I'd say it'll work if you make sure no bits wind up inside Bill | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | You can grind them down or wack em off. The lug nuts hold the drum on tight. Don,t ruin those wheels. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | I agree with red and wrenchbender. Cut the rivetts off. The wheel has to be flush with the mounting surface to be seated properly. Also, if you have access to a torque wrench, tighten the lug nuts up with that for the final tightenign. About 65 ft/lbs shoud do with the stock studs on a 1/2 ton.
Bill Burmeister | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I don't have this arrangement on my 1 Ton so I am curious as to the function of these rivets. Why are they there? | | | | | Joined: Sep 2006 Posts: 42 Junior Member | | Junior Member Joined: Sep 2006 Posts: 42 | I think I read somewhere that the hub and drum was riveted together to elimanate a task in the assembly line....???? | | | | | Joined: Nov 2002 Posts: 394 'Bolter | | 'Bolter Joined: Nov 2002 Posts: 394 | Better yet lets just drill them completely out counetrsink the hole and install countersunk rivits. We do it all the time here at Lockheed where I have been working for the last 35 years. :p | | |
