| | | Forums66 Topics128,024 Posts1,055,393 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2001 Posts: 162 Shop Shark | | Shop Shark Joined: Apr 2001 Posts: 162 | I am taking the truck to the body shop for paint today. I would like to add aftermarket air in the future but funds are going to paint.
If I am having my paint man fill up holes and clean up the firewall and want to provision for an ac bulkhead what do you recommend?
I have heard of a bulkhead that fits in the original hole where the heater was and everything else would be under dash.
Does it sound feasible to just fill most of the firewall holes but a couple for wiring harness, gauges, and steering column and use the heater hole for a bulkhead?
Or is there a bulkhead connector that can be bought that will work later for aftermarket ac?
tim
53 3100 1929 Ford Roadster Pickup 1934 Ford Pickup 68 Plymouth Satellite RR Clone 2 Door My Fleet
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | You can get one to fit the heater motor hole, you can also get universal ones and make your own hole. Or you can make a hole and put the lines through with grommets, that eleminates two places for each line to leak. Be sure you don't fill holes you will need later. How are they being filled? | | | | | Joined: Oct 2000 Posts: 108 Shop Shark | | Shop Shark Joined: Oct 2000 Posts: 108 | Hey Bessie,
Did you ever get the pictures I sent you of my "burb" project?? Never heard back from you. I sent them to the .....mchsi email. Do you still use that one??
Stingray | | | | | Joined: Apr 2001 Posts: 162 Shop Shark | | Shop Shark Joined: Apr 2001 Posts: 162 | Stingray,
Didn't get them. I am @earthlink.net but same prefix.
Hope all is well.
Bessie.
Grigg,
I will ask him how he fills the holes.
Thanks.
