7 members (Gdads51, Ponchogl, Brian Moore, TUTS 59, Hotrod Lincoln, Bill Hanlon, 1 invisible),
90
Mod | | | Forums66 Topics128,045 Posts1,055,528 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2001 Posts: 34 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2001 Posts: 34 | I am wondering what are the years six bolt C10 rims, the six bolt kind, are interchangeable. I need one and can’t seem to find one. Is there a source on line?
Any info on this would help
Sandy | | | | | Joined: Jan 2001 Posts: 613 Member | | Member Joined: Jan 2001 Posts: 613 | at least 1960-70.if you ever get to charlotte,nc ive got several i'll give you. | | | | | Joined: Jul 2006 Posts: 707 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 707 | '87 rims have the right offset. '88 do not. 1951 3800 Be the change you want to see. -hotshoe
| | | | | Joined: May 2006 Posts: 63 Member | | Member Joined: May 2006 Posts: 63 | Sandy- Here is a website that may be of help to you. http://www.rallyamerica.com Also - beyond 1970 GM continued to use the 6 bolt pattern on their 4WD trucks. I used a set of 15x8 Rally wheels on my '67. Good Luck! Guy | | | | | Joined: Dec 2001 Posts: 34 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2001 Posts: 34 | thanks for all your help!! | | |
