3 members (Dennys28, 87GN, 1 invisible),
113
Mod | | | Forums66 Topics128,059 Posts1,055,818 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2006 Posts: 6 New Guy | | New Guy Joined: Dec 2006 Posts: 6 | Help me out here guys, Im so confused. I have a 1950 5window 3100 and I want to replace the cab. Do all 47-53 cabs interchange? 3100's with 3600 & 4100 and COE's I know that the 51's started with the vent windows so could I use my '50 doors on a later year cab?
I work & work & Work and I still cant afford it!
'50 3100 5 window ( under construction)
| | | | | Joined: Aug 2002 Posts: 154 'Bolter | | 'Bolter Joined: Aug 2002 Posts: 154 | Yep. All cabs will interchange except the COE's.Doors will interchange also. | | | | | Joined: Mar 2006 Posts: 262 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 262 | A '49 to '53 cab will bolt right up to your frame. '47 and '48 have a 3 point mount and '49 to '53 have a 4 point. I think I read on here someplace that all the cabs are the same (1/2 ton and up), but I know the front fenders and hoods on the bigger trucks are longer than those on the 1/2 ton. Hope this helps. I'm sure you'll get some info soon.
My truck: She may not be the prettiest girl at the dance, but she's all mine!
