1 members (JW51),
137
Mod | | | Forums66 Topics128,049 Posts1,055,741 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2006 Posts: 163 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 163 | Does anyone know the Part #'s for the outer and inner front roller wheel bearings for a 51 1/2 ton pickup. I know a place about 30 miles from here who sells bearings of all types but I need a part # for the roller bearing. :confused: Any help would be appreciated. | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Can you pull one of the old ones for them to cross reference?
| | | | | Joined: Nov 2006 Posts: 247 'Bolter | | 'Bolter Joined: Nov 2006 Posts: 247 | Jon do you have your old bearings? There should be a bearing number on both the inner cup and outer race for both your inner and outer bearings. It should be stamped with the manufactures name. Jim | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Jon D,
Your description is a little ambiguous...are you intending on replacing the BALL bearings with tapered ROLLER bearings?
I think the ball bearings would have to be replaced on 'application'...what year and model truck.
The swap to tapered roller bearings would include new cups and cones...bearings and races.
I think your best bet is to do a search in one of the forums. There have been numbers called out for these items, along with seals, but I don't think they are standard industry numbers.
Soneone who has done it will probably pop in and give us both the hot skinny.
I think your best bet, if you are intending on dumping the ball bearings and going with roller bearings would be one of the vendors that sell the complete package...seal and all!
Stuart | | | | | Joined: Jul 2006 Posts: 163 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 163 | atomarc, I was intending on replacing the ball bearings with tapered roller bearings for a 51 half ton. I guess I failed to mention that. I know vendors sell the roller bearing packages but thought I could purchase them close to home at a much lower cost??? I'll do a more through search on the forum site. Thanks. | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | I believe they are specifically produced for that application. I don,t think you will find them in the regular bearing suppliers. As you can tell I,m not shure of that & have been noted to be wrong before. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Jul 2006 Posts: 163 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 163 | Searched the thread and found previous posts. Also, checked Classic Performance Parts and did a little reading there. From what I have found, most think ball bearings are fine and should work okay on a 51. I guess they should since they have been used for 50+ years. May just buy new ball bearings and the correct grease and keep the older ball bearings after all. Just can't overtighten ball bearings. | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Good research...good choice! Stuart | | | | | Joined: Dec 2006 Posts: 1,464 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,464 | Good choice for stock brakes but if you have any plans for a disc upgrade in the future I'd spend the money now for the rollers, you'll need 'em. | | |
