2 members (Frank50, Joe H), 120 guests, and 1 robot.
Topics128,175
Posts1,057,056
Members48,460
#222428 12/21/2006 10:30 PM
I usually cringe when I see wood anywhere but the bed on a truck but this guy made some oak running boards that don't look all that bad. Anybody considering making some can get an idea what they would look like here:
http://cgi.ebay.com/ebaymotors/1953...hZ012QQcategoryZ5348QQrdZ1QQcmdZViewItem
Curt B.
You Tube
Wood running boards look great if done right.
Hmm, those are literal running boards. Not bad looking but I would detract the lack of original steel boards from the value of the truck. Not bad as a stop-gap measure while you fine real ones, and they won't rust out.
The thing I would be leery of is the rear fender support, the rear fenders are supposed to bolt to the running boards.
Paint & Body Shop moderator
Also due to the diamond quilt pattern covering the kick panels in the cab I would suspect some shoddy rust repair on that whole truck. Those should be steel and they hold up the cab.
