| | | Forums66 Topics128,030 Posts1,055,428 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2006 Posts: 125 Member | | Member Joined: Oct 2006 Posts: 125 | I need to tear my heater apart and check on either a disconnected or faulty temp. control valve or a plugged heater core (have no circulation through the heater). I have looked in the '55-'59 Factory Assy. Manual but can't find an exploded view of the heater. Does anyone have a pic handy??? I am guessing I just remove a dozen or so tiny hex-head screws and the front pulls off, but would rather have a "look" inside before I take it apart.
'58 3600 350/4-sp/stepside/big window cab '59 3100 235/4-sp/stepside
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | there's some info on the 2 types of factory installed heaters in the accessories manual , but as they're optional accessories,there is no parts view of any of them anyplace, they come assembled! if you have the deluxe heater, yes, you hafta take the case into 2 parts, the control [if original] is mounted on the core inlet - if you have the standard heater, there's no factory control in it - easiest to work on either if you take it right outta the truck cuz you can't really get at all the screws in place Bill | | | | | Joined: Oct 2006 Posts: 125 Member | | Member Joined: Oct 2006 Posts: 125 | Thanks Bill....to completely remove the heater does it unbolt from the engine compartment or from the cab?? I see where to take the front cover off in the cab. My heater is the deluxe model. I also have new heater levers ordered (on backorder..  . I am guessing they are easy to install once the heater controls are removed from the dash. Any other hints?
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | the heater comes out by unbolting the 4 [5-6?] studs that go thru the firewall on the engine side and removing the heater hoses - prolly easier if the control cables are disconnected first, and the levers are pretty straight forward once you have the control out I'm finished up my busy season now, and have been intending to work up some detailed info on the TF heaters, seein I've got a couple of each  I'll pull out the delux one I restored last year and take some pics tomorrow Bill | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | On the deluxe heater, there's 5 nuts- 3 for the heater core box, and 2 for the blower fan housing. for the core box, one is under the battery tray, one just to the engine side of the tray, and the last one is behind the battery. the two for the fan housing are to the outside of the tray.
Bill Burmeister | | | | | Joined: Oct 2006 Posts: 125 Member | | Member Joined: Oct 2006 Posts: 125 | red58..GREAT!! Cant wait to see the pics. I love pics..  I have been printing alot of the pics and "how to's", makes a really great quick reference for those times the computer isnt handy. longbox55.. thanks for the specifics. Nice to know exactly what to look for. My hair is gray enough already
| | | | | Joined: Feb 2006 Posts: 549 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 549 | it's easier to get to the 4 bolts that hold the box in if you remove the battery holder first. i took the glove box out as well so it access to all of the ducts was simple. Here's a pic of the box in the cab, with the front taken off. click here | | | | | Joined: Oct 2006 Posts: 125 Member | | Member Joined: Oct 2006 Posts: 125 | avette4me, what are the wire things at the right lower edge of the core?
| | | | | Joined: Feb 2006 Posts: 549 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 549 | that was some pine needles that ended up in there some how...  | | | | | Joined: Feb 2006 Posts: 549 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 549 | while you're at it, i would recommend getting all new cables... | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | got one batch of delux heater pics on webshots Joe - there's 3 nuts to remove for the core box and 3 for the blower section note the control in the un-restored one has been eliminated, as most are after 10,20,30 years because they always start leaking ... I've seen a few different designs of controls, and the only one repro'd now that I know of is for the tri5 car, won't fit most of the Harrison truck heaters Bill | | | | | Joined: Oct 2006 Posts: 125 Member | | Member Joined: Oct 2006 Posts: 125 | thank you Bill...pics will come in very handy
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | cool, yeah that one - last I checked around, anyplace that had'em listed said they weren't available ... I decided it'd be better to put a different style under the hood anyway where leaking wouldn't be a problem Bill | | |
