0 members (),
196
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,081 Posts1,056,078 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#22231 01/28/2005 8:12 PM | Joined: Aug 2004 Posts: 56 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2004 Posts: 56 | I have my '40 GMC stripped down to the frame with the drive train still on. I want to remove the drive shaft. What is the process? G. Lee | | |
#22232 01/30/2005 8:01 AM | Joined: Aug 2004 Posts: 196 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2004 Posts: 196 | take it loose a the end of the tranny after that your on your own | | |
#22233 01/31/2005 11:41 PM | Joined: Mar 2004 Posts: 313 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 313 | Hi GLee, If you don't have one, I would get a shop manual from gregsonline.com He has manuals that go back to your year of truck. They will have a detailed explaination on how this is done. It's really not that hard. Over the years, I learned alot by using the shop manual I have for the 47 through 53 trucks I have had. KT ---------------------------------------- 1949 3/4 ton & 1950 1/2 ton (in peices right now)!
1953 3100 with 1957 235, T5 and 12 bolt 373 rear
