1 members (Materman), 107 guests, and 3 robots.
Topics128,072
Posts1,055,906
Members48,429
#2217 05/09/2003 4:43 PM
I wondered if anyone has experience in towing their vehicle for any long distance? I wanted to tow my 2 ton Chev, with a single speed rear end, with a tow bar ala RV style. I set up a bar and it tows beautifully behind my Silverado 1/2 ton. Rather than drive it the 150 miles to my lake cottage I thought it would be OK to tow but I wanted an opinion on speed. Is it OK to go at a higher speed than you would normally drive the vehicle? I like a speed of 35mph when I cruise around with it! That speed is a bit of a nuisance on a highway and there are no back roads for the most part. Is, say 55mph too fast for that rear end?
Thanks for any experiences anyone could share.
Cheers, George
#2218 05/09/2003 4:55 PM
Search the archives on towing - there are some precautions to disconnect the driveshaft for some types of trannys (torque tube?) as the lubrication of the driveline is driven by the engine turning.
-Boyo
'48 Willys CJ-2A / '55.1 Chevy 3600 / '66 Austin-Healey 3000 / '04 Volvo wagon (parenthood!?)
#2219 05/09/2003 4:59 PM
The one time my 62 two ton was towed they disconnected the drive shaft. It's only a couple of nuts so easy insurance.
P.S. Reading your post again, I would not want to be driving in front of you when you are trying to stop that towed TWO TON rig from 55 mph with only the brakes of your 1/2 ton Silverado.
54 3100 with 235
62 flatbed dump C60 with 261
#2220 05/09/2003 6:26 PM
If the brakes are working, have someone ride in the truck as a brakeman. And I wouldn't go much over 45, due to brakes and wheel bearings.
Fred
52 3600
69 C-10
#2221 05/09/2003 6:30 PM
eek I would not attempt towing that much weight 10 miles at highway speeds without trailer brakes. Get that thing going 50 MPH and it will push your 1/2 ton half a mile (or more) before it stops.
#2222 05/10/2003 1:09 AM
If it were me doing this , I would have a driver in the towed truck who could apply the brakes just as if the truck were on a rope ,, ie ,, doing most of the stopping where possible .
Then I would cruise off at a gentle pace , say , 40 mph max .
And hang a "ON TOW" sign on the back .
No worries grin
But it may be more of an adventure to drive it all the way , and have the silverado delivered by a family person. smile
#2223 05/10/2003 1:13 AM
Bad Idea,don't do it. Not too keen on the idea of an accomplice riding for 3 hours trying to guess when you are braking either ( some states this is agin the law).
longtrail
It is only possible to live happily ever after one day at a time.
#2224 05/10/2003 1:18 AM
With the front wheels on a tow dolly the accomplice won't see a thing either.
54 3100 with 235
#2225 05/10/2003 3:27 AM
Moderator
Moderator
2 Offline
DON'T DO IT!!
The 2-Ton will out weigh your little 1/2 car truck by almost two to one.You are risking your life and those that are on the road with you.
Trust me I learned the hard way.
Don
"The Flag Pole"
1946 2-Ton grain truck
1946 3/4-ton pickup,
1953 1-ton pickup
1957 1-ton flatbed dually,
1954 Pontiac Straight Eight
#2226 05/12/2003 1:22 AM
Thanks guys!
You're right. I won't do it. The 2 ton has a curb weight of 5585lbs with a stake box, so the specs say. That is too much to be towing without brakes and I should have realised that. I'll do as Dusty says and just make an adventure out of driving it on my intended trip.
When I posted this question I was at the lake and at the same time corrected my e-mail address to a new one. It kicked me off the forum and I couldn't re-enter until I got a new password after returning home this afternoon. That's why I hadn't responded to your replies.
Thanks for your good information.
Cheers, George
#2227 05/13/2003 3:02 AM
Jarge,
isn't the highway two lanes each way all the way over to the Ontario border? Every time that I have driven that stretch, I have never seen it busy. Now that all changes entering Ontario when it goes to one lane and all the hills appear.
1951 1 Ton Completed
#2228 05/13/2003 2:30 PM
Hi t-nix!
You're right about the highway. It is a double lane both directions. Truck traffic has increased by leaps and bounds so it is pretty busy now. I go to my place another route which takes me slightly north of Warroad, Minnesota. It is a quiet highway. Not quite the road that Glenn A. Foster mentions but will still be a good trip.
Cheers, George
#2229 05/14/2003 6:07 PM
Been there done that, will think twice before I try that again... I pulled a 4000lb car on a tow bar back from Worchester Ma. to Toronto (500mi) between 45 and 55mph all the way with a 2400lb Pontiac 4cyl 2L engine, What a ride and through the mountains of Ma. and New York. But you should have seen the looks i got at the toll booths and when I got to Canada Customs and they tried to get the car behind me to back up...as it was a little too close behind..
