| | | Forums66 Topics128,154 Posts1,056,857 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#22204 07/27/2003 10:38 PM | Joined: Mar 2003 Posts: 9 Member | | Member Joined: Mar 2003 Posts: 9 | So I have been given a straight six as a gift for my AD truck build. In an effort to learn what I can about it before tearing it down and having the machine shop give it the old once over I wrote down the serial numbers and the casting numbers. The casting nos. tell me it's a 250 from 66-84 the particularly 73 or 83. I know so little about 6s that I couldn't tell you the difference between the two if it was stamped on the valve cover. So can anybody glean anything from these: F0424CCA 13l210808
I appreciate your help. Thanks- Andy | | |
#22205 07/31/2003 4:39 AM | Joined: Apr 2003 Posts: 942 'Bolter | | 'Bolter Joined: Apr 2003 Posts: 942 | Online 6 cylinder info seems hard to find. A Hollander Interchange Manual could tell you just what you have, but mine only goes to '72. With only limited info online, I saw CCA as a 250 in a '73 Nova w/Powerglide and as a 250 in a '77 Nova w/TH350. You can also find date codes on many of your engine parts. (Example *A173* = January 1, 1973). List your date codes and we can help you further.
'60-'72 Chev/GMC Fan GMC 9500 Fan Detroit Diesel Fan
#22206 07/31/2003 4:47 AM | Joined: Apr 2003 Posts: 942 'Bolter | | 'Bolter Joined: Apr 2003 Posts: 942 | Date Code on block should be just above starter, almost hidden behind it.
#22207 07/31/2003 11:12 AM | Joined: Jan 2001 Posts: 662 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 662 | | | |
#22208 07/31/2003 4:27 PM | Joined: Mar 2003 Posts: 9 Member | | Member Joined: Mar 2003 Posts: 9 | Thanks guys. I don't have easy access to the block as it's in Broadhead Wisconsin with the truck it's going into. The rent is free and the guy lets me use his tools so... All the same the stuff chuckthetruck tossed out looks reasonable to me.
Thanks again -Andy | | |
