3 members (Jay R, Hanks custodian, 1 invisible), 122 guests, and 1 robot.
Topics128,052
Posts1,055,727
#221979 12/17/2006 3:47 AM
Apprentice
Apprentice
New guy here. I am installing a 1954 235 into a 1946 half ton frame. My question is does the rear motor mounts support the bellhouesing up off the rear engine crossmember or does the bellhouseing / crossmember have metal to metal contact. I have ordered several sets of mounts from J. Carter but as I mentioned, I'm a new guy. What grade bolts should be used for the vertical / horizontal connections. Stumped. Great forum.
#221980 12/17/2006 6:21 AM
3B Offline
Hy Metricnut, the rear engine mounts are bolted to the bellhousing and then a vertical bolt secures them to the crossmember, as for the bolt grade, grade 5 should be sufficient, hope that helps.
#221981 12/17/2006 12:19 PM
Apprentice
Apprentice
Thank you. Im trying to ensure I have the correct rear motor mounts. When installed on the bellhouseing the bell h. rides about half an inch above the cross member. Seems light a lot of weight to support. Is this correct?
#221982 12/17/2006 1:10 PM
no less than grade 5 bolts or you could be sorry spend a little now saves a lot latter
ya I know a few rednecks.Thay all drive chevys to,
Proud member of the Old Dominion Stovebolt Society
AND A MARINE
trucks range from 1942 1/2 ton to 1965 fire engine
