4 members (klhansen, baldeagle, Simon1954, pkr), 63 guests, and 10 robots.
Topics128,019
Posts1,055,343
Members48,419
#221975 12/17/2006 2:57 AM
I found a 41-46 1.5 ton in a hedgerow (on county property) recently. I am in the process of rescuing it before the county turns it into scrap metal. Just have to get through some red tape even as a county employee.
My question is if the fender width is the same on these bigger trucks as the pickups? If not, how much wider is it? What about frame width? Same or different as PU's?
I tried a search on here for the answer before asking, but didn't find an answer.
1965 Chevy C-10 Longbed Stepside
#221976 12/17/2006 4:50 AM
Former Workshop Owner
The fenders are bigger to accomodate the larger tires. The frame is bigger and heavier also. I am not sure if the frame rails are the same distance apart. If I get a chance tomorrow, I will measure them.
~ J Lucas
2006 GMC Envoy 4.2 I6
2023 Ram 2500/Cumins 6.7 I6
2002 Silverado 2500 Gas 6.0
1941 Chevy 1/2-Ton
1942 Chevy 1.5-Ton SWB
My Flicker Photos!
#221977 12/17/2006 12:19 PM
Thanks John. Looking forward to the answer!
#221978 12/17/2006 1:07 PM
cab and grills are the same hood also the fenders are diffrent biger opening for tires frame shouls be same under cab
ya I know a few rednecks.Thay all drive chevys to,
Proud member of the Old Dominion Stovebolt Society
AND A MARINE
trucks range from 1942 1/2 ton to 1965 fire engine
