6 members (Shade Baby, TexasA&M48Truck, tclederman, Hotrod Lincoln, Bill Hanlon, 1 invisible), 82 guests, and 2 robots.
Topics128,094
Posts1,056,483
Members48,444
Junior Member
Junior Member
I have a 49 Chevy shortbed and I'm trying to put a side mounted spare tire carrier on it. I have found a dimpled fender and the mounting bracket, but can't seem to get a normal sized tire to fit. Does anyone know if there is a special wheel that has to go on it...or does anyone have any suggestions?
What is the size of your tire? How far off from fitting is it?
There were different side-mount carriers for 1954/55 1/2 ton trucks with 6:00x16 (and 15") tires and for 6.50x16 tires). This might have also been the case in 1953. Also, larger trucks had other side-mount brackets (but did not need the dimpled fender).
Gigster...are you saying that the tire doesn't fit on the tire mount or won't fit in the recess in the fender? If mounting assem.you have is for a 3/4 or 1-ton, the mounting studs will be too far apart for your wheel to go on. If that's the case, I have a 1/2 ton assem.& need a 3/4 -1 ton assem. we could trade.
