| | | Forums66 Topics128,024 Posts1,055,395 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2006 Posts: 85 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2006 Posts: 85 | first of all i have a 51, 3100, i want to lower, and i.ve heard some of you mention you can remove some of the leaf's but i don't know which ones and how many, please advise,,, ron | | | | | Joined: Mar 2005 Posts: 1,513 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,513 | Removing the bottom 2 leaves will drop your bumper about 1 1/2" - 2". If you take any more you have to deal with removing/replacing spring clips which could be done but I can't say when it becomes unsafe. Mine rode alot better after that too.
Curt B.
1952 1300 Canadian 1/2 ton restomod You Tube | | | | | Joined: Jun 2006 Posts: 85 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2006 Posts: 85 | | | | | | Joined: Dec 2003 Posts: 1,554 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 1,554 | When I first lowered the rear of my 55,I took 4 leaves out of each spring .I believe it was the lower ones.Since then I upgraded to new 5 leaf springs,new mounts,shocks,etc.I also flipped the rearend.Its right down there where it looks good and mean. | | |
