4 members (Hotrod Lincoln, DadsFirstPickup, pkr, JW51), 96 guests, and 1 robot.
Topics128,048
Posts1,055,624
I just bought a 55 Chevy 3100 stepside but the front brake drums are missing. Does anyone know if any Chevy 6 lug brake drum can be used to replace them? thanks
The hubs are riveted to the brake drums. I assume you mean there are no brake drums on it. But you confuse me asking if any 6-lug rim can replace them.
Any ½-ton drum from '51-59 should work. Later ones may work but someone else will have to confirm.
If it's just the drum, they're the same to '70. The hub I'm not too sure about.
Bill Burmeister
