7 members (Shaffer's1950, Steelonsteel, Hotrod Lincoln, 2-Ton, homer52, Tiny, mo2cyl),
112
Mod | | | Forums66 Topics128,049 Posts1,055,665 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2006 Posts: 21 New Guy | | New Guy Joined: Mar 2006 Posts: 21 | I just bought a 55 Chevy 3100 stepside but the front brake drums are missing. Does anyone know if any Chevy 6 lug brake drum can be used to replace them? thanks | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | The hubs are riveted to the brake drums. I assume you mean there are no brake drums on it. But you confuse me asking if any 6-lug rim can replace them.
Any ½-ton drum from '51-59 should work. Later ones may work but someone else will have to confirm. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | If it's just the drum, they're the same to '70. The hub I'm not too sure about.
Bill Burmeister | | |
