0 members (), 64 guests, and 4 robots.
Topics128,014
Posts1,055,325
Members48,419
#221173 12/06/2006 2:35 AM
Guys,
A little while ago I finally got me a '51 GMC 1/2T.
Its great!!!! and I drive it everywhere.
It has 15" 6 bolt wheels that are about 5 - 5 1/2" wide and I need one more for a spare tire.
Is there a wheel off a modern truck like Toyota or mid size Dodge or whatever that will fit the old GM bolt pattern and width and center hole requirements????
This is just for a spare and hopefully I will neever use it.
Thanks in advance.
Jeff
#221174 12/06/2006 5:54 AM
Hi Jeff,
I think toyota is the same bolt pattern, but the backspacing may be off. The dodge dakota 6 bolt is a different bolt pattern completely.
If I was looking for wheels for your truck I would probably look for any 1/2 ton wheel up until '72 or any 1/2 ton wheel from a '73-86(87?) Chevy 4x4. Those will all bolt on, now you have to find the correct size.
Good Luck.
Correct me if I'm wrong crew.
#221175 12/06/2006 1:07 PM
Can't do that, Colin. You're right. Anything Chevy with 6 holes up to 1987. The later ones have the same bolt pattern, but the offset is wrong, as you'd see if you tried 'em. Ask me how I know . .
1951 3800
-hotshoe
