| | | Forums66 Topics128,021 Posts1,055,354 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2005 Posts: 6 New Guy | | New Guy Joined: May 2005 Posts: 6 | Guys,
A little while ago I finally got me a '51 GMC 1/2T. Its great!!!! and I drive it everywhere. It has 15" 6 bolt wheels that are about 5 - 5 1/2" wide and I need one more for a spare tire. Is there a wheel off a modern truck like Toyota or mid size Dodge or whatever that will fit the old GM bolt pattern and width and center hole requirements???? This is just for a spare and hopefully I will neever use it. Thanks in advance.
Jeff | | | | | Joined: Apr 2001 Posts: 439 Shop Shark | | Shop Shark Joined: Apr 2001 Posts: 439 | Hi Jeff,
I think toyota is the same bolt pattern, but the backspacing may be off. The dodge dakota 6 bolt is a different bolt pattern completely. If I was looking for wheels for your truck I would probably look for any 1/2 ton wheel up until '72 or any 1/2 ton wheel from a '73-86(87?) Chevy 4x4. Those will all bolt on, now you have to find the correct size.
Good Luck.
Correct me if I'm wrong crew. | | | | | Joined: Jul 2006 Posts: 707 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 707 | Can't do that, Colin. You're right. Anything Chevy with 6 holes up to 1987. The later ones have the same bolt pattern, but the offset is wrong, as you'd see if you tried 'em. Ask me how I know . . 1951 3800 Be the change you want to see. -hotshoe
