| | | Forums66 Topics128,010 Posts1,055,299 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2005 Posts: 44 Wrench Fetcher | | Wrench Fetcher Joined: May 2005 Posts: 44 | I'm attempting to buy a Chevy 6 from someone here on the forum. I think he said it was from a -63.... numbers on a pad down by the dist. are " f03iipk" does these help in identifying the engine? My main question is whether it is a 230 or a 250. Any and all help appreciated...
Hello, Welcome to America press '1' for English Puess '2' to disconnect until you learn to speak English
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Could the "ii" in the code actually be "11"? if so, according to the numbers list I have, it comes out to be a 292, 160 hp, built at Flint on March 11, used with Powerglide trans.
Bill Burmeister | | | | | Joined: May 2005 Posts: 44 Wrench Fetcher | | Wrench Fetcher Joined: May 2005 Posts: 44 | cool, I'd take a 292. I think there is a visible difference between the 230/250 and the 292 in the appearance of the lifter side cover, true? If he could shoot us a pic of the right side of the engine, we should be able to see the difference. I'll ask for a pic. Thanks for the quick response there Longbox !
| | | | | Joined: Aug 2005 Posts: 81 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2005 Posts: 81 | Hi scs65... to confirm the info that Longbox55 gave you, I also show the same information, that is IF the 'ii' is 11.
Boogity, Boogity, Boogity Let's go racin boys. Drive fast, turn left. GO #20.
Real trucks where bowties.
