2 members (JW51, Phak1),
141
Mod | | | Forums66 Topics128,269 Posts1,058,402 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#22083 04/09/2002 5:11 AM | Joined: Mar 2002 Posts: 8 Member | | Member Joined: Mar 2002 Posts: 8 | Are there any good pics online of the mounting brackets for the 235 external oil canister? I have a canister,where can I find the bracket? | | |
#22084 04/09/2002 6:31 AM | | Anonymous Unregistered | | Anonymous Unregistered | Put an ad in the Swapmeet section & you may get lucky on this part. | | |
#22085 04/09/2002 3:10 PM | Joined: Dec 2001 Posts: 1,745 Member | | Member Joined: Dec 2001 Posts: 1,745 | Mine is held onto the intake manifold with two U bolts.
54 3100 with 235 62 flatbed dump C60 with 261
#22086 04/09/2002 3:31 PM | Joined: May 2001 Posts: 1,908 'Bolter | | 'Bolter Joined: May 2001 Posts: 1,908 | Click on my home-page symbol. Maybe you can see enough in the one picture. (The last time I pointed folks at my home-page, Geocities shut it down saying there was too much traffic for a freebie.) 1948 3/4-Ton 5-Window Flatbed Chevrolet 34 Years. Now with a '61 261, 848 head, Rochester Monojet carb, SM420 4-speed, 4.10 rear, dual reservoir MC, Bendix up front, 235/85R16 tires, 12-volt w/alternator, electric wipers and a modern radio in the glove box.
#22087 04/10/2002 2:25 AM | Joined: Apr 2002 Posts: 16 Junior Member | | Junior Member Joined: Apr 2002 Posts: 16 | Mine as well is held on by U bolts | | |
#22088 04/10/2002 1:22 PM | Joined: Mar 2002 Posts: 18 Member | | Member Joined: Mar 2002 Posts: 18 | Don't know if you have a factory assembly manual but according to the 58 manual the filter is not not mounted perpendicular. Think the top is tilted 8 degrees away from the engine Don't know how important it would be ( except to some anal judge in a show ) but there must have been a reason I guess.
Life is to serious to be taken seriously
#22089 04/10/2002 3:16 PM | Joined: Dec 2001 Posts: 1,745 Member | | Member Joined: Dec 2001 Posts: 1,745 | That is very interesting. I just took my filter off to do some headwork and thought the previous owner had been sloppy. I thought, as I took it off that at least I would put it back on straight. Duh
I wonder if the angle is with the exit tube uphill from the lowest point. This would aid in collection of heavier items since they don't want to go uphill. Thanks, I don't think I would have checked my manual for it's installation.
#22090 04/10/2002 3:22 PM | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | OGRE9 & Eugene,
The year of the 235 engine might be important to the installation and the type of filter. I think that the 261 engine changed in 1958 (58-62) to a full-flow oil filter. I hope that someone will comment on this, especially if the same thing in true for the 235 engine.
If Eugene has a '55 235 engine, the filter canister is most likely installed as in previous years. My 1953 AC instructions does not state/show anything about an 8 degree tilt.
By the way, I understand that an engine with full-flow oil filtration should not use the old canister filters that were used on the by-pass oil filtration engines (pre-'58?).
Tim | | |
#22091 04/11/2002 1:59 PM | Joined: Mar 2002 Posts: 18 Member | | Member Joined: Mar 2002 Posts: 18 | Tim Can't speak to other years or displacements. Just thought it might be useful for him to check before installation . As to the filter elements I have had two guys tell me in all seriousness that back in the day some guys used rolls of toilet paper in their canisters . Probably not up to factory specs but certainly cheap George
#22092 04/11/2002 2:10 PM | Joined: Aug 2000 Posts: 800 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 800 | The 235 thru '61 did not have even a bypass filter as standard. At least on pickups. | | |
#22093 04/11/2002 3:15 PM | Joined: May 2001 Posts: 1,908 'Bolter | | 'Bolter Joined: May 2001 Posts: 1,908 | Frantz sold a canister that took toilet paper. Somebody here or on another old truck page was looking for one. 1948 3/4-Ton 5-Window Flatbed Chevrolet 34 Years. Now with a '61 261, 848 head, Rochester Monojet carb, SM420 4-speed, 4.10 rear, dual reservoir MC, Bendix up front, 235/85R16 tires, 12-volt w/alternator, electric wipers and a modern radio in the glove box.
#22094 04/13/2002 6:21 AM | Joined: Mar 2002 Posts: 990 Member | | Member Joined: Mar 2002 Posts: 990 | i dunno, toilet paper filter? I have heard of em, but sounds crappy to me! :p | | |
#22096 04/14/2002 4:37 AM | Joined: Mar 2002 Posts: 3 Member | | Member Joined: Mar 2002 Posts: 3 | Again,,,,,,,,2 U BOLTS holding mine on also.  | | |
#22097 04/15/2002 12:53 PM | Joined: Feb 2000 Posts: 50 Member | | Member Joined: Feb 2000 Posts: 50 | I have 2 trucks, the 1952 has the filter mounted with 2 ubolts. the 1953 has a flat base and is mounted on the firewall. I understand there were a couple of manufactures so it depends on what you have. Wix was one AC was another and AC Delco was another. Don't know if there were any more. Chevy engine orange is real close to the original color of the AC delco.
'52 Chevy 5 window, it ran when I parked it '53 Chevy 5 window, running the streets with me. '55 Massey-Ferguson, tearing up the dirt '89 Harley FXSTS, suicide clutch '92 Harley FLSTC, equal time with the '89
#22098 04/15/2002 12:57 PM | Joined: Feb 2000 Posts: 50 Member | | Member Joined: Feb 2000 Posts: 50 | correction, thats Wix and AC DElco, I had ac down twice.
#22099 04/15/2002 7:56 PM | Joined: Oct 2001 Posts: 7 Member | | Member Joined: Oct 2001 Posts: 7 | I've got an extra canister w/u-bolts sitting in the garage. Make me an offer if you are intersted. | | |
#22100 04/16/2002 2:17 AM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | First, here's a picture of mine. Fred\'s Engine There were many variations on the filters. Fram was the most popular. Some had larger fittings for the full flow 261. Some used tp, which doesn't do much for me. My Fram takes a Wix 51006 element, about $10 locally.
Fred 52 3600 69 C-10
