2 members (walterhvogel, klhansen), 114 guests, and 2 robots.
Topics128,035
Posts1,055,559
#220638 11/29/2006 1:52 PM
Does any body have a diaghram of the top end of the column. The bearing and the plastic are shattered. the p.o.wired the horn to the outside of the column. any help would be appreciated. thanks Lou. H.
#220639 11/29/2006 4:43 PM
3B Offline
Hy biglou55, could you please tell us what year truck we're talking about. Did you want to know about turn signal stuff as well?
#220640 11/29/2006 5:53 PM
It,s a 65 I think the turn signals might be all right. I wont know about them until i re wire all the outside lights. It is the bearing in the plastic piece with the wire on it that goes below or inside the turn signals . and what does the wire hook to. The horn ????? I hope i have cleared up what i am looking to fix. Thanks Lou.
#220641 11/29/2006 6:04 PM
Lou - the bearing goes into the top of the column, below the big nut that holds the wheel on, the wire goes down the column and out under the dash to plug into the harness [to the horn], prolly where yer current button hooks up - when you push the horn button it puts a ground on that wire to complete the horn circuit
#220642 11/29/2006 7:56 PM
Red 58 (bill) Does it go on first then the plastic turn signal assembly -spring -wheel -wheel nut -horn button. what holds the bearing down on the shaft an e clip. I dont think the p.o. put it back together right at all. thier is probably some parts missing. That is why i was looking for a diagram to see if anything was missing.The wiring is messed up when you hit the brake pedal the left turn signal indicator lights up. that is the next obstacle (wiring ) after i get it to steer. eek Thanks Lou.
#220643 11/29/2006 8:52 PM
sounds like the right order, don't think yer missing anything - what holds the bearing in is light friction fit, the steering shaft inside, the column sleeve outside - never seen any pics of that area, other than maybe the assembly manual
the brake/turn mixup might be in the turn signal harness hookups, the brake light/turn indicator use some of the the same circuit, as the brake lights go thru the turn sig mechanism
#220644 12/01/2006 1:24 AM
I have an idea that might not be worth the trouble but how hard would it be to put a 61 Chevy steering wheel on a 81 Pontiac column?
