1 members (Ponchogl),
108
Mod | | | Forums66 Topics128,281 Posts1,058,466 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2006 Posts: 84 'Bolter | | 'Bolter Joined: Nov 2006 Posts: 84 | Are there any brake drum options for the 3/4 ton truck? can the later 1953 drums be adapted in some way? what are you guys using or doing for brakes beside front end conversions? I would like to keep the 8 lug wheels if possible.
Thanks. Trey | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | I'm told the early 3/4-ton drums are hard to find.
I think a '48 is huck style brakes and believe you have to convert the entire setup, backing plates and everything else, to use later bendix type brakes.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | I'm also interested in this if anyone has any additional information it sure would help. There are a lot of 3/4 ton Chevy AD trucks out there, not as many as the 1/2 tons, that is reflected by what the vendors are selling. You can only do so many brake jobs before the drums finally need to be replaced also. I’m sure with all the 3600s that are still on the road that someone has done a full brake job and found a solution to the problem. Maybe it was discussed to death a year ago, but since I joined in September I haven’t seen the subject come up, with one exception. One of the forum members replied that he found some good used ones in a junkyard. Where are you guys finding junkyards that keep cars/trucks around that long? There is a lot more money in scrap around here so they are running every thing through the crusher bout as fast as they get them in. They certainly don’t let them sit around for 50 years. Lets have some educated discussion on whether the bearing diameter and spacing would be the same. I would love to have access to 40’s through say, 80’s 3/4 ton spindles, backing plates and drums and put them up on the surface plate with an indicator, to make some comparisons. As we have found with the differentials, I’m sure there are some of the later parts that would work, even if you had to do some machine work to modify them. Denny Graham Sandwich, IL
Denny G Sandwich, IL
