| | | Forums66 Topics128,096 Posts1,056,482 Members48,444 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#22055 02/15/2003 5:23 AM | Joined: Nov 2002 Posts: 3 Junior Member | | Junior Member Joined: Nov 2002 Posts: 3 | some how my rear rims got bent and i wanted to buy new rims and tires anyhow. I have a 54 gmc 3/4 ton and wanted it to have a little sportier look (if possible). Does anyone know what size rim and tire would be best without spending a lot of money. I was told that i would be able to fit a 15x10 rim under the fender but i wasn't too sure about that | | |
#22056 02/17/2003 8:14 PM | Joined: Mar 2002 Posts: 384 Shop Shark | | Shop Shark Joined: Mar 2002 Posts: 384 | My 55 1st series had 15" rims on it that were most likely aftermarket. I went back to 16" rims like the originals, and would like to part with my 15" rims eventually. I now have 3 15" rims and will return to the junk yard to get more. My 15's are probably 7 inches wide or so. If you are interested, maybe we can work something out.
55 1st Chev.
#22057 02/17/2003 8:32 PM | Joined: Jun 2002 Posts: 19 Member | | Member Joined: Jun 2002 Posts: 19 | abalderama: Check your E-mail. I might have what you're lookin' for. Darwin
If you think you can or if you think you can't, either way you're right.
#22058 02/17/2003 8:33 PM | Joined: Nov 2002 Posts: 3 Junior Member | | Junior Member Joined: Nov 2002 Posts: 3 | i dunno, i've have to deal with another problem first with my truck. I was looking for a wider rim anyhow. i was just curious about what kind of offset and everything would work and how much rubber i could fit under the truck | | |
#22059 02/17/2003 9:04 PM | Joined: Jun 2002 Posts: 19 Member | | Member Joined: Jun 2002 Posts: 19 | abald It was a close fit to get the wheels on. It looked good with them on, but it was hard to steer - especially when parking. If you like I'll measure wheel offset when I get home and let you know tomorrow. One other thing I noticed is that the mounting studs were a little short for the alloy wheel. If I wanted to use these I would opt for longer studs. Darwin
