0 members (),
39
Mod | | | Forums66 Topics128,014 Posts1,055,327 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2005 Posts: 45 New Guy | | New Guy Joined: Dec 2005 Posts: 45 | I finally stripped everything off the frame of my 54 and can see the middle crossmember just behind the cab is rusted pretty bad. I'm going to have to replace it. Does anyone know where I can get a replacement for it? This is the crossmember with the Steel gossets.
Thanks, | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | I'd suggest advertising in the parts wanted part of the swap meet for a replacement frame.
People trying to sell frames don't seem to get much for them, and I'm sure it would be less work to clean up another frame than to swap that crossmember.
And if you can't get a complete frame you may be able to get a used crossmember the same way.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Jun 2006 Posts: 2 Junior Member | | Junior Member Joined: Jun 2006 Posts: 2 | Hey Morepower16, I have a friend in Porter Texas that has one and has access to a couple more. Vern | | | | | Joined: Dec 2005 Posts: 200 Shop Shark | | Shop Shark Joined: Dec 2005 Posts: 200 | I see frames themselves go really cheap and pretty often to boot...might be better just to grab up a nuther one and start with sandblastin.. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | As you most likely already know, a '54 frame is different from earlier frames. | | |
