7 members (TooMany2count, 55shaker, klhansen, Phak1, 3800GUY, Gdads51, 1 invisible),
75
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,138 Posts1,056,440 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2006 Posts: 8 Junior Member | | Junior Member Joined: Jul 2006 Posts: 8 | Has anyone here ever used those convertors you can get that bold to your hub and convert your 6 lug wheels to a 5 lug wheel? Tell me what you think and how they worked. Thank you! Roger | | | | | Joined: Nov 2006 Posts: 1 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2006 Posts: 1 | i put 54 chevy pass hub and drums on my 54 pick up if this helps. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Not a big fan of these. I work in a tire/alignment shop and have seen what they can do to the bearings and tires. They will move the rim outboard, which changes the scrub radius and wheel centerline in relation to the bearing. Unless a wheel that has an offset to bring the centerline back to the correct position is used, it can overload the bearing. Also, by altering the scrub radius, this can cause handling problems and accellerated tire wear. There's also the danger of a wheel off situation if the nuts are not torqued correctly. In our shop, we do not service vehicles that have adapters like this due to the liability. Personally, if you want 5 lug, you'll be much happier swapping the axle and doing the 5 lug front brake (disk) conversion.
Bill Burmeister | | |
