2 members (Hush, delky), 141 guests, and 0 robots.
Topics128,126
Posts1,056,354
Members48,441
#220540 11/28/2006 3:53 AM
Junior Member
Junior Member
Has anyone here ever used those convertors you can get that bold to your hub and convert your 6 lug wheels to a 5 lug wheel? Tell me what you think and how they worked. Thank you!
Roger
#220541 11/28/2006 4:05 AM
i put 54 chevy pass hub and drums on my 54 pick up if this helps.
#220542 11/28/2006 4:08 AM
Not a big fan of these. I work in a tire/alignment shop and have seen what they can do to the bearings and tires. They will move the rim outboard, which changes the scrub radius and wheel centerline in relation to the bearing. Unless a wheel that has an offset to bring the centerline back to the correct position is used, it can overload the bearing. Also, by altering the scrub radius, this can cause handling problems and accellerated tire wear. There's also the danger of a wheel off situation if the nuts are not torqued correctly. In our shop, we do not service vehicles that have adapters like this due to the liability.
Personally, if you want 5 lug, you'll be much happier swapping the axle and doing the 5 lug front brake (disk) conversion.
Bill Burmeister
