1 members (DadsFirstPickup), 85 guests, and 1 robot.
Topics128,118
Posts1,056,305
Members48,439
Junior Member
Junior Member
I have bad spindles for my '58 1/2 ton. I got some spindles from a guy on Stovebolt that were supposed to be from a 58 or close but the King pin slides through them. Anyone have any clue on what to do or where to get a new set of spindles or knuckles?
Thanks, Roger
roger1,
There are several different sizes of king pins available depending on the amount of wear on the truck. It's possible that the spindles you bought either had oversize bushings installed, worn out bushings or no bushings at all.
If the spindle is mechanically OK...has good threads and intact bearing seats then they should be a good candidate for new bushings when you buy and install your new king pin set.
Oversize pins are required when the axle eye is worn and wobbled out. When you install oversize pins, the "hole" in the bushings which you insert into the spindle are larger. If you stick a standard OD pin in them, it will fall right through. There has to be bushings in the spindle!
Hope this answers some of your questions.
Stuart
