1 members (homer52),
66
Mod | | | Forums66 Topics128,072 Posts1,055,906 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#22019 12/24/2002 1:45 PM | Joined: Aug 2001 Posts: 7 Apprentice | | Apprentice Joined: Aug 2001 Posts: 7 | I just purchased a 1960 GMC C60 farm truck. It runs beuatiful but has a terrible gas leak at the top of the carb float bowl. This is a 305 v6 and it has a holly 1 barrel down draft carb. All my other v6's have stromberg 2 barrels. It pretty grimey yet but I can't seem to see any numbers. Can someone shed some lite on this model of Holley for Me? Knowledgable sources for Kits and nformation? Other suppliers that still have parts for the old v6's. Thanks. Todd | | |
#22020 12/24/2002 4:26 PM | Joined: Nov 2002 Posts: 2,766 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,766 | todds - we show Holley model 1904 list number 1915 used on 1959 GMC 305 V-6. The Holley literature doesn't show it for 1960, but it easily could be original. If you view the carburetor such that the word Holley on the bowl is visible, look to your left on the boss of the fuel inlet, and if you have a strong magnifying glass, and a pair of "young eyes" you will see the list number stamped.
Personally, I would suggest replacing both intake and carburetor with the 2 barrel Stromberg if you have them available. If not, parts are available for the Holley.
Jon. Good carburetion is fuelish hot airThe most expensive carburetor is the wrong one you attempt to modify. If you truly believe "one size fits all," try walking a mile in your spouse's shoes!The Carburetor Shop | | |
#22021 12/26/2002 5:27 AM | Joined: Feb 2000 Posts: 268 Shop Shark | | Shop Shark Joined: Feb 2000 Posts: 268 | First off, you Did not buy a 1960 GMC C60, a c60 is a chevy model, you truck would be a 3500, 4000 or 5000 model. do you know which it is? if not whats the vin number on the tag in the door frame? I can tell you a lot by that number. also whats the number on the engine, it could be a 305 B or C, both use a different carb and manifold. Check these page to see were to find the engine number: GMC V6 Engine Data Page . | | |
#22022 12/26/2002 11:59 PM | Joined: Nov 2002 Posts: 2,766 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,766 | todds - for carburetor applications on G.M.C. trucks try this link: http://www.thecarburetorshop.com/trgmc.htm Jon. Good carburetion is fuelish hot airThe most expensive carburetor is the wrong one you attempt to modify. If you truly believe "one size fits all," try walking a mile in your spouse's shoes!The Carburetor Shop | | |
