3 members (78buckshot, Ridgeback, 1 invisible),
109
Mod | | | Forums66 Topics128,035 Posts1,055,443 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2005 Posts: 37 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2005 Posts: 37 | Can anyone tell me the proper name for this part There is very little info in my parts books on this leaf hanger bracket.(the one that is riveted to the the frame needs replaced) I would like to put an add in the parts wanted but I don't know exactly what its called. Thanks Rob | | | | | Joined: Oct 2006 Posts: 26 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2006 Posts: 26 | leaf spring shackle bracket | | | | | Joined: Apr 2005 Posts: 37 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2005 Posts: 37 | | | | | | Joined: Jul 2005 Posts: 640 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 640 | It's a "Thingy." I have them all over my truck. They come in all shapes and sizes, and nobody knows what you're talking about when you try to explain it to them. Uh, which part of the spring shackle are you referring to? | | | | | Joined: Apr 2005 Posts: 37 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2005 Posts: 37 | this part As you can see there is a split near the grease fitting Thanks Rob | | | | | Joined: Mar 2006 Posts: 319 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 319 | Maybe you already looked at the 1929-1954 parts book. This illustration seems to call it simply a hangar. http://chevy.tocmp.com/1929_54chevyparts/07/434.HTM If you go to part # 7.112 from the illustration for example, it is described as "Hanger, rear spring front". I'm not sure which hanger you have pictured. Hope you find your replacement part.
"Nothing astonishes men so much as common sense and plain dealing." - Ralph Waldo Emerson
| | | | | Joined: Nov 2004 Posts: 117 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2004 Posts: 117 | This would appear to be the right (passenger side) rear spring hanger. It is a frame part and not normally found in the aftermarket. I have one for a 54/55.1 1/2 ton. Send me an e-mail if you are interested and I'll dig it out and send you a picture.
cgresham1212 If you don't drive it, why have it? 55 1st Series 3100 5 window
| | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | Post in the parts wanted section,i'd bet you'll find one quick. 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
