5 members (Wally / Montana, Chris's 46 / 515, mick53, Stovebolt48, 1955 1 Series), 133 guests, and 3 robots.
Topics128,189
Posts1,057,337
Members48,469
#219663 11/13/2006 7:54 PM
Can anyone tell me the proper name for this part
There is very little info in my parts books on this leaf hanger bracket.(the one that is riveted to the the frame needs replaced)
I would like to put an add in the parts wanted but I don't know exactly what its called.
Rob
#219664 11/13/2006 8:02 PM
leaf spring shackle bracket
#219665 11/13/2006 8:03 PM
#219666 11/13/2006 9:47 PM
It's a "Thingy." I have them all over my truck. They come in all shapes and sizes, and nobody knows what you're talking about when you try to explain it to them. wink
Uh, which part of the spring shackle are you referring to?
1948 Chevy 1/2-Ton
"Tuesdays with Morris"
In the Legacy Gallery
Find it - Fix it - Drive it
#219667 11/13/2006 10:42 PM
this part
As you can see there is a split near the grease fitting
Rob
#219668 11/13/2006 11:16 PM
Maybe you already looked at the 1929-1954 parts book.
This illustration seems to call it simply a hangar.
http://chevy.tocmp.com/1929_54chevyparts/07/434.HTM
If you go to part # 7.112 from the illustration for example, it is described as "Hanger, rear spring front". I'm not sure which hanger you have pictured.
Hope you find your replacement part.
"Nothing astonishes men so much as common sense and plain dealing." - Ralph Waldo Emerson
#219669 11/14/2006 1:31 AM
This would appear to be the right (passenger side) rear spring hanger. It is a frame part and not normally found in the aftermarket. I have one for a 54/55.1 1/2 ton. Send me an e-mail if you are interested and I'll dig it out and send you a picture.
cgresham1212
If you don't drive it, why have it?
55 1st Series 3100 5 window
#219670 11/14/2006 3:15 AM
Post in the parts wanted section,i'd bet you'll find one quick.
1951 3100 Chevrolet
