3 members (RLB, papas52, 1 invisible),
91
Mod | | | Forums66 Topics128,154 Posts1,056,851 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2006 Posts: 213 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2006 Posts: 213 | My gas gauge is inoperable.Where should I start to check? It's probably the fuel sending unit, but I want to make sure it's not the gauge itself. Any help is appreciated. Joe
54 Triumph TR2(rhd)needs total resto. 60 Apache 10 stepside shortbed 99 Excelsior Henderson | | | | | Joined: Mar 2005 Posts: 1,029 Member | | Member Joined: Mar 2005 Posts: 1,029 | What does the gauge read? | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | cal55,
The following procedure will prove the integrity of the wire from gauge to tank, and tell you if the problem is the gauge or sender.
I don't know if your sending unit is as accessible as the units on earlier AD truck, so this test might be a bear.
With the key ON...pull the wire at the sending unit. The gauge should read FULL.
With the key ON..ground the same wire to a known good clean ground. The gauge should read EMPTY.
If all this happens, it tells you the gauge is working and the wire isn't compromised.
This means it is your sending unit..OR, the tank/sending unit isn't properly grounded. Good luck.
Stuart | | | | | Joined: Nov 2006 Posts: 213 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2006 Posts: 213 | Thanks for the replies, at least I know where to start from. The tank reads 1/4. Thanks again,I really appreciate the help. Joe
54 Triumph TR2(rhd)needs total resto. 60 Apache 10 stepside shortbed 99 Excelsior Henderson | | | | | Joined: Mar 2005 Posts: 1,029 Member | | Member Joined: Mar 2005 Posts: 1,029 | Does it read the same with the key off as it does with the key on? If not the same both ways, then it almost has to be a stuck sending unit. | | | | | Joined: Nov 2006 Posts: 213 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2006 Posts: 213 | Thanks, I'll take a closer look this weekend. The trucks not at my home yet, it should be by the weekend I'm hoping. Joe
