6 members (1955 1 Series, Justhorsenround, Hotrod Lincoln, Otto Skorzeny, Hugh63c10, KEVINSKI), 81 guests, and 2 robots.
Topics128,142
Posts1,056,481
Members48,441
#219601 11/12/2006 4:45 PM
My gas gauge is inoperable.Where should I start to check? It's probably the fuel sending unit, but I want to make sure it's not the gauge itself. Any help is appreciated.
Joe
54 Triumph TR2(rhd)needs total resto.
60 Apache 10 stepside shortbed
99 Excelsior Henderson
What does the gauge read?
cal55,
The following procedure will prove the integrity of the wire from gauge to tank, and tell you if the problem is the gauge or sender.
I don't know if your sending unit is as accessible as the units on earlier AD truck, so this test might be a bear.
With the key ON...pull the wire at the sending unit. The gauge should read FULL.
With the key ON..ground the same wire to a known good clean ground. The gauge should read EMPTY.
If all this happens, it tells you the gauge is working and the wire isn't compromised.
This means it is your sending unit..OR, the tank/sending unit isn't properly grounded. Good luck.
Stuart
Thanks for the replies, at least I know where to start from. The tank reads 1/4. Thanks again,I really appreciate the help.
Joe
Does it read the same with the key off as it does with the key on? If not the same both ways, then it almost has to be a stuck sending unit.
Thanks, I'll take a closer look this weekend. The trucks not at my home yet, it should be by the weekend I'm hoping.
Joe
