Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
6 members (Joe H, Otto Skorzeny, Shade Baby, 55shaker, 2 invisible), 102 guests, and 4 robots.
Topics128,274
Posts1,058,436
Members48,490
#219502 11/11/2006 12:02 AM
Now that I am getting close to painting, I started looking at the underside of the hood. We did not blast it, but it is totally smooth on the top. But, underneath, it looks awful. I was thinking of some kind of insulation, but I can't find something specially cut for it. Any suggestions for insulation or a liner coating? It is a '53 bolt about to be loaded down with primer coats and four coats of red. (but not under the hood).
#219503 11/11/2006 12:30 AM
WHY DON'T YOU SPRAY A "RINO" COATING UNDER THE HOOD,
it should help with insulation too ! There is also a ruberized
sound proof coating used on frames etc. that can be used !
Check 1st to make sure that they are not overly "flamable"!
'53 GMC "Ranger"
#219504 11/11/2006 2:39 AM
por-15? rust encapsulator? and paint if necessary
rhino liner sounds cool too
tom
I don't suffer from insanity, I enjoy every minute of it!
