0 members (), 40 guests, and 2 robots.
Topics128,030
Posts1,055,428
Members48,422
#2194 09/22/2003 4:06 AM
How can I identify the transmission and carb make and model? Are there part numbers I can get from them?
#2195 09/25/2003 3:56 AM
Can't guess at what you have without seeing, so can't be sure you've got a rochester carb - but if so, i'm sure they all have a number on the casting - i haven't seen one without it - if memory serves, on the front of the float bowl. Anyway, there will be something on it, post what you have and I'll look up all the spec's I can find - I have an ancient but really good old "Motor" light truck manual that lists all the carb options and their specs for that year.
#2196 09/25/2003 7:36 PM
Ok It is offical. Its a 400 turbo.
