6 members (UtahYork, 2-Ton, 68ironhead, Stovebolt48, 50Chevy3100, 1 invisible), 71 guests, and 3 robots.
Topics128,187
Posts1,057,212
Members48,465
Junior Member
Junior Member
Looks like it is spot welded in the front...Do I have to cut or grind it out?? 1953 3100
Sean
Never Let Them Go
If you are not saving it, just grind it or cut it out.
If you are saving it, us a drill and drill the spots out or use a spot weld remover.
Junior Member
Junior Member
Thats what it looked like....I will try and save it...just in case I want to go back to bench...As it stands 2005 chevy van front seats.
Thanks for the info
Sean
Never Let Them Go
Sean S,
I'm not sure on this, but when you remove the frame, you are going to loose some stiffness in the floor...might have to make up for it somehow.
Stuart
Junior Member
Junior Member
under the floor??? Or would the frame and the center consol be enough?
Sean
Never Let Them Go
Sean S,
This is just a cautionary thought. After you buzz the factory frame piece off, jump around on the floor and see if it has become squishy!
I have never done this, but it just looks like the frame adds some integrity and strength to the big flat floor board...maybe not.
Stuart
Junior Member
Junior Member
I will ck it out Stuart. Thanks for the heads up... I have seen them cut out...but never looked under the cab.
Sean
Never Let Them Go
automarc is right the seat riser or frame does reinforce the floor. Probably lots of them have been cut out for custom seats. Good luck.
Professional Novice
