2 members (Danielbolt, Steelonsteel), 82 guests, and 3 robots.
Topics128,095
Posts1,056,492
Members48,444
#219461 11/10/2006 9:16 PM
Junior Member
Junior Member
I just got done with the back part of my 1953 3100 1/2 frame with the bed off .It's semi-gloss and looks great. I also put it under the dash to make sure we dont get any rust before I sound proof the cab. That stuff goes a long way. Well have a good one....Today is Sponge Bob day....."The best day ever" as per my son.
grin
Sean
Never Let Them Go
#219462 11/11/2006 12:39 AM
I
I Offline
Sean, you forgot one important part with the por-15, dont get it anything you dont want painted, including your self. It dont come off easily and on your skin you have to wear it off. This lesson was learned the hard way.
Jeff
1947 Chevy 6400 2-ton
1953 3/4-ton
It was fun while it lasted
#219463 11/11/2006 2:06 AM
Junior Member
Junior Member
Iowa Trucks 59 how would you know ???
Dennis
Dennis
#219464 11/11/2006 2:24 AM
Also (and I've said this before) if you spray it, make sure to wear a respirator. Not the cheapie dust mask type, you'll at least need a charcoal filter type. Or better yet, a fresh air type hood. Getting it in your lungs is really bad.
Bill Burmeister
#219465 11/11/2006 2:35 AM
Junior Member
Junior Member
this stuff is tough stuff.....i am brushing it on the outer rails and spraying it on the hard to get spots. but what a great job it does...prep,prep,prep...and it works like a champ...and just brushing it on i did not wear any respirator at first...then I was getting a buzz...so now I am....and I doNt SEe anNy SiDE Affectz YEt.
Sean
Never Let Them Go
#219466 11/11/2006 2:42 AM
I
I Offline
Well Dennis, its like this,,someone kept painting spots for me to get into.
Hey everyone, Dennis is the other half of this team, and this is his first post ever on the bolt!!
Jeff
1953 3/4-ton
#219467 11/11/2006 6:06 AM
welcome to the 'bolt D&J....
I used POR-15 under my 39's cab and frame rails... still looks great after 6 years...
Another quality post.
Real Trucks Rattle
#219468 11/11/2006 4:57 PM
Junior Member
Junior Member
Hey Guys, I understand that you can top coat POR-15 with what ever you want or just leave it as it is. Did you all use it as your finish coat?
Rezman
Snapoff brand tools
1948 Chevy 6400
1949 Chevy 4400 (parts truck)
#219469 11/11/2006 5:47 PM
Rezman, just remember that POR-15 is photo-sensitive. If you leave the coated piece in sunlight it will start looking milky.... it won't affect the protective features but won't look purely black. POR-15 suggests using their TopCoat over the top, I've also seen people use regular paint over it while it's still tacky.
Lee
1965 Chevy C-10 Gallery page
My Chevy truck pages more info and pictures!
1961 Studebaker Hawk
1962 Shasta 16' AirFlyte Travel Trailer
1941 Case Model S tractor
#219470 11/12/2006 3:46 AM
If it's left to completely dry, they suggest using their Tie Coat primer. It's made to work with POR 15 as a base. It's pretty good on it's own, too.
Bill Burmeister
#219471 11/12/2006 5:06 AM
I
I Offline
We paint part of an inner fender, with some left over por-15. It accidently got left outside for a couple weeks in the sun. It turned a lite white color, that rubbed off on your hands. The can says not to let it be exposed to sunlite, and to top coat it, by sanding with 600 grit paper, and using there paint. The top coat in a lot duller black than the por-15. This stuff is tough. I've heated part for bolt removal, when i missed a broken one. The torch didnt even phase the por-15. Niether did my sand blaster. The only thing that takes it off well is the angle grinder.
Jeff
1953 3/4-ton
