| | | Forums66 Topics128,035 Posts1,055,564 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2006 Posts: 19 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2006 Posts: 19 | I have an 82 v8 camaro, does anyone on here know if I can use the front clip on my 54 1/2 ton pickup ?? thanks for any help Danny | | | | | | Anonymous Unregistered | | Anonymous Unregistered | Too wide and I believe it uses struts but not sure. Check out some of the recent threads regarding suspension options for AD trucks. Best option is an IFS kit. | | | | | Joined: Sep 2006 Posts: 19 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2006 Posts: 19 | thanks houston54 , maybe that's why everyone stays with the 70's camaro front clips.. thanks for your help Danny | | | | | Joined: Jun 2006 Posts: 382 'Bolter | | 'Bolter Joined: Jun 2006 Posts: 382 | Don't belive you can Dan. The 67-81 Camaro with the unboltable sub-frame is the one you are thinking of. Your '82 has a cradle/crossmember that unbolts but would not be the same because of the strut type front suspension. | | | | | | Anonymous Unregistered | | Anonymous Unregistered | The second generation subframe is also too wide. You will have have to keep the front end up or you will have wheel/tire/fender interferences which after final paint are not good to find out about. Wheel back spacing does not solve the problem. Go to car shows and talk to people who have done the modification before you decide to go that route. From my personal experience, the IFS kit is the best way to go on the 47-55.1 series trucks. You can make anything work but it will be a challenge. | | | | | Joined: Sep 2006 Posts: 19 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2006 Posts: 19 | thanks for all the help guys, look like an IFS is the way to go many thanks Danny.. | | | | | Joined: Sep 2006 Posts: 38 Junior Member | | Junior Member Joined: Sep 2006 Posts: 38 | I have heard and read several times in the past that the AMC Pacer fromt clip is a perfect fit for the AD pickups.
Rezman
Snapoff brand tools .................................. 1948 Chevy 6400 1949 Chevy 4400 (parts truck)
