2 members (baldeagle, Ponchogl),
56
10
Mod | | | Forums66 Topics128,020 Posts1,055,345 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2006 Posts: 26 Apprentice | | Apprentice Joined: Oct 2006 Posts: 26 | I'm wanting to smooth out and repaint my dash in my 52' 3100. how easy is it to remove? Is it better to just leave it in the truck?
westerman 52' CHEVY 3100
| | | | | Joined: Mar 2005 Posts: 197 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 197 | Hey Westerman, I don't know about the '52, but I would imagine it would be pretty easy to physically remove the dash. I'd say the main issue would be to make sure you've got all your wires, etc. labeled really well. There are probably about 6 or so screws or bolts holding it in. Good luck.
Neil 1940 GMC 1/2 Ton
| | | | | Joined: Mar 2004 Posts: 874 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 874 | Westerman, Depending on how much work you want to do, it may be better to leave it in the truck because it is spot welded in. If you do decide to take it out, pick up a spot weld cutter. | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | westerman,
For all practical purposes, the dash isn't removable.
Stuart | | | | | Joined: Mar 2005 Posts: 197 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 197 | Wow, I didn't know they spot welded the dash in on those trucks! Mine, although it IS 12 years older, is simply held in by screws. I guess they decided that noone would ever need to remove them. You learn something new everyday. Good luck anyway. Let us know how it all works out.
