| | | Forums66 Topics128,047 Posts1,055,533 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#21920 04/04/2002 3:51 AM | Joined: Apr 2002 Posts: 5 New Guy | | New Guy Joined: Apr 2002 Posts: 5 | i just got a 1962 gmc surburan that had the stock v6 and tranmissiom removed . the front end has power steering. would like to install 350 and auto and use the powersteering . any guidance would be great thanks turtle | | |
#21921 04/04/2002 4:21 AM | Joined: Jan 2001 Posts: 47 Member | | Member Joined: Jan 2001 Posts: 47 | Turtle Check out mounts for 60 - 66 Chevy with small block but watch for different frames some trucks had tortion bars etc. I'm not sure if GMC and Chevy is the same frame but my 65 GMC ( factory V6 Power Glide ) has 65 Chevy truck 283 with 68 Chevelle Power Glide. The rear mounts look factory and it looks as if the front mounts were slid back on the frame and new holes drilled . | | |
#21922 04/04/2002 12:11 PM | Joined: May 2001 Posts: 41 Member | | Member Joined: May 2001 Posts: 41 | One aspect that is very often over looked is the suspension when going from a 6 cyl to 8 cyl. The front springs are different. You should actually change the front springs when changeing over. It will handle much better and ride much better not to mention safety.
37 Chevy 1/2 Ton 86 Chevy Blazer 98 Drudge 24 valve Cummins One worn out Timberjack
#21923 04/04/2002 4:30 PM | Joined: Jan 2001 Posts: 47 Member | | Member Joined: Jan 2001 Posts: 47 | Woodhick You might be right but in the case of the V6 I'll bet the small block Chevy is lighter. I would bet money mine has original springs for 1/2 ton V6 and it rides fine for truck and steers ok (no power steering). | | |
