0 members (),
123
Mod | | | Forums66 Topics128,078 Posts1,056,035 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2006 Posts: 40 Member | | Member Joined: Aug 2006 Posts: 40 | The doors close okay, but they still have play after they're shut. Most of the weatherstrip is still there...at least enough to seal the doors if they would close completely. When thee're shut, you can still push and pull and get about 1/4 inch play back and forth. the latches and hinges are in good shape. Is there an adjustment that will solve this...along with new weatherstrip? | | | | | Joined: Oct 2006 Posts: 339 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 339 | DR, If You are talking only 1/4 inch, You might move the lock plate in a smidgeon...It sure won't take much to eat up that 1/4...The other alternative is to replace the door seals...JMO BB | | |
