2 members (MaxStewart, dunfire),
129
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,127 Posts1,056,680 Members48,452 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2006 Posts: 40 Member | | Member Joined: Aug 2006 Posts: 40 | Whats kinda problems will I have replacing my stock 3600 front axle with a 3100 front axle. Mostly concerned about the steering box...everything else should be the same...I think. | | | | | Joined: Apr 2001 Posts: 439 Shop Shark | | Shop Shark Joined: Apr 2001 Posts: 439 | Try this. Basically, the flat spot on the top of the axle that contacts the springs is in a different location. | | | | | Joined: Mar 2004 Posts: 874 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 874 | I considered this swap on my '52 3600 and like TooMany says it will be a direct bolt in swap. 1/2 tons and 3/4 tons used the same front springs from 47 to 55. Also of note...1/2 ton axles used 1/2" u-bolts while 3/4 tons used 9/16" u-bolts. | | | | | Joined: Apr 2001 Posts: 439 Shop Shark | | Shop Shark Joined: Apr 2001 Posts: 439 | I stand corrected. Thank you. Sorry 'bout that Dash. | | | | | Joined: Aug 2006 Posts: 40 Member | | Member Joined: Aug 2006 Posts: 40 | Lots of good stuff here guys. Now I'm not skeered anymore! Dash Riprocker | | |
