| | | Forums66 Topics128,113 Posts1,056,619 Members48,450 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2006 Posts: 53 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2006 Posts: 53 | Who here has experience with replacing their under bed fuel tank with an aftermarket or later model one? I saw a suburban with a late model chevy tank under the rear, and I thought that was a great idea. But I want to keep the filler neck on the side of the cab, which seems like it could be dangerous if the tank wasn't designed for that vehicle. Any input is appreciated. | | | | | Joined: Feb 2002 Posts: 2,893 Socket Breaker | | Socket Breaker Joined: Feb 2002 Posts: 2,893 | Why replace the tank at all? Is it leaking? Doing a custom job? Wanting the space behind the seat? There is a good article about the in cab gas tanks at jim carter's site: http://www.oldchevytrucks.com Technical Articles 1947-1955 poster Mechanical In Cab Gas Tanks <- good article about the in cab gas tanks enjoy... -W | | | | | Joined: Jul 2006 Posts: 53 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2006 Posts: 53 | It's a Panel, not a truck. So the tank has to be under the bed. I'm putting a big block in it that will probably get 10 mpg, so a 16 gallon tank won't cut it. | | |
