4 members (Joe H, Phak1, GMCJammer51, moparguy), 53 guests, and 0 robots.
Topics128,196
Posts1,057,398
Members48,471
i took the valve cover off my truck and as i removed the bolt antifreeze started spewing out the radiator was not preesurized in fact it has not been run in 3 days or so. There is a pretty big puddle of antifreeze under the truck. i am kind of worried about this it is a chevy 235 and i want to know if it is realy serious and if i need to fix anything else while i am replacing the head gasket thanks
Hudson
Water came out of the bolt hole for the valve cover? Sounds like someone broke a bolt and tried to drill it out, went to deep and drilled through the water jacket.My older brother used to think he was the original Mr. Goodwrench, he did this to a 250 cu.in. 6cyl. engine.Couple ways to fix this, take the head off and bring to a machine shop they can fix it, or do the easy cheap way, drain the water to a level about half way down the radiator when you take the bolt out, then when you put the bolt back make sure and put some sealer on the threads around it and snug it down good, not to tight just good and snug then fill water back up. You'll be ok.
Tommy
59 apache 1/2t
261 short stepside
Could also be a cracked head. Either way, the machine shop will be able to tell you.
Fred
52 3600
69 C-10
