3 members (Otto Skorzeny, 3B, 1 invisible),
45
9
Mod | | | Forums66 Topics128,013 Posts1,055,322 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2004 Posts: 16 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2004 Posts: 16 | I have a 94 S-10 pickup; it's an "SS" model. There is a small switch on the dash below the fog lite switch that has an "I" and an "O" on it. I can't seem to find out what it does. Does anyone know or have something similiar? It looks like a factory switch and is only like 3/8 wide by about 1 inch high, and is a rocker switch. Thanks all. | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | acmegarage,
That's the 'belly-button' switch...
"I"= inney
"O"= outey
Could it possibly be a button IN/OUT for 4WD or Quadratrack?...a non-installed option on your truck!
Stuart | | | | | Joined: Jan 2004 Posts: 16 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2004 Posts: 16 | Thanks, that makes sense. | | | | | Joined: Mar 2005 Posts: 1,029 Member | | Member Joined: Mar 2005 Posts: 1,029 | Could it be a courtesy switch to flash the taillights when passing? The description sounds like a typical appliance switch; 1 for on, 0 for off. | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | From the main page of "General Truck Talk" Please, no flaming, advertising or anything else not directly related to the care, restoration, preservation or use of old GM trucks! Off-Topic discussions go in the Greasy Spoon Forum! Emphasis added for effect. | | |
