1 members (JakeM),
129
Mod | | | Forums66 Topics128,275 Posts1,058,571 Members48,492 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#21844 10/23/2003 6:14 PM | Joined: Sep 2003 Posts: 65 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2003 Posts: 65 | I have a '59 chevy apache 1/2 ton with a 3.9:1 ring/pinion. Do you guys reccommend swapping that w/ a 3.38 or lower? I'm not looking to haul [censored] around town, but I would like to cruise without putting excess ware on my soon to be rebuilt 235. The tranny is a 3speed...thanks pork
1959 Chevy Fleetside 3100 Series BBW
#21845 10/23/2003 6:37 PM | Joined: Jan 2001 Posts: 687 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 687 | To answer your initial question... Can I cruise 65 w/3.90 rear end? Sure you can. With overdrive! But changing to a 3.38 or numerically lower would work too. I have a 3.73 rear end in my '66, but the overdrive in fourth gear puts me at 2200 rpms at 70mph. To me that's cruising. -ftyler | | |
#21846 10/23/2003 6:40 PM | Joined: Mar 2003 Posts: 49 Member | | Member Joined: Mar 2003 Posts: 49 | My 59 panel truck has a 235 with the stock 3.90 rear end and 3 sp tranny. It will cruise at 2800-3000 rpm max. A freind followed me on the freeway and said I was doing 63mph. I have 235 75 15" tires about 29" tall. I am looking for some tall skinny tires 33" I should be able to do 70mph if I can find some that fit without rubbing. | | |
#21847 10/23/2003 9:30 PM | Joined: Apr 2002 Posts: 23 Member | | Member Joined: Apr 2002 Posts: 23 | http://www.gearvendors.com/cg2wdt.html theres some great overdrives for Muncies and Borg-Warners. I know of one person (F-150 Lightning) who put a Gear Vendors Overdrive unit behind his E4OD and had 3.73 gears in the back. When he was going to Lightningfest in Kansas in Sept, he was cruising at 70-75 most of the way, and his engine was practically idling at about 1700RPM. After a couple years I think the money you save on gas would easily pay for it. Drew
55 2 dr 210- after college project 56 2 dr 210- after '55 project "D'oh"
#21848 10/23/2003 11:19 PM | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | I have 3.08 gears in my 55 1st Suburban. It cruises at 55 turning about 1500 RPM. I don't remember what the tach says at 70, but with the GMC 270 it will easily run 70+.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | |
#21849 10/23/2003 11:39 PM | Joined: Jul 2000 Posts: 504 Member | | Member Joined: Jul 2000 Posts: 504 | pork chop,,,, Go to the RPM Calculator on the Randy\'s Ring & Pinion Page.. Enter your tire size, final tranny ratio, then you can try different rear end ratios to see determine your final RPM's..
Bill M 53 GMC Hydra-Matic
Home Page http://home.comcast.net/~bd97/index.html
When you argue with a fool, two fools are arguing..
#21850 10/23/2003 11:47 PM | Joined: Dec 2001 Posts: 1,745 Member | | Member Joined: Dec 2001 Posts: 1,745 | I still have the stock 3.90 in my 54 with 235 and 30 inch tires and am barely able to attain freeway speed without the engine sounding like it will self distruct.
I already have the 3.55 ready to go in but even with that it will not be a freeway cruiser.
54 3100 with 235 62 flatbed dump C60 with 261
#21851 10/24/2003 2:56 PM | Joined: Sep 2003 Posts: 65 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2003 Posts: 65 | thanks for the input guys. What I think I'll do is put the 3.90 back in since I have never driven the truck and see how she runs after the restoration. If I'm satisfied then I'll probably just leave it in and if not it's a pretty easy swap I'll just replace it. My 3rd gear ratio is 1:1 so i'll check out that website that calculates rpm. To be honest I'm only going to drive the truck to cruises and shows so I might be worrying for nothing...thanks pork
#21852 10/24/2003 3:50 PM | Joined: Feb 2003 Posts: 129 Shop Shark | | Shop Shark Joined: Feb 2003 Posts: 129 | First thing, do you want to be going 65 MPH on 45 year old drum brakes and straight axle?
My 59 runs a 235 and 3 speed with a stock 3.90:1 rear end and it screams at anything over 60 and seems to be best driven at 55 MPH. | | |
#21853 10/25/2003 2:50 AM | Joined: Sep 2003 Posts: 23 Member | | Member Joined: Sep 2003 Posts: 23 | I routinely cruise my 56 3100 at 70mph with straight axle and drum brakes. That's Sierra mountains, flat valley lands as well as bad California traffic. If your truck is well maintained and in good condition, no problem. Never had brake fad and have always had the truck under control. I have had this truck since the 70's -- no crashes. Do not tailgate, drink, eat or yak on the cell phone while driving. Trucks take longer to stop than a Honda Civic, so think defensively.
I used to have 3.90 gears with 650x16 tires. I now have 235x15 tires and 3.38 rear gears, much nicer at 70mph. | | |
