1 members (Hanks custodian), 103 guests, and 10 robots.
Topics128,014
Posts1,055,324
Members48,419
#218195 10/22/2006 12:25 AM
So my dad and I are trying to figure out what is wrong with our front driver's side drum on our '54 1/2 ton. If we bleed the wheel cylinder the wheel will turn smoothly. If we apply the brake pedal the shoes grab and the wheel locks. However, when we release the brake pedal the wheel does not free up. It is almost like the fluid can't flow back towards the master cylinder. Has anyone else had this kind of problem? If so, what did you do to fix it? The shoes, springs and other brake hardware appear to be in good condition. If we need a new brake line, is is easy enough and cheaper to make our own, or will we have to buy a whole new steel line set? Thanks.
#218196 10/22/2006 12:37 AM
Greg,
The flex hose going to that brake could have become soft and separated internally. This will allow the brake fluid to expand the wheel cylinder on brake application, but the hose can collapse and restrict fluid movement that allows the wheel cylinder to retract, or relax.
Stuart
#218197 10/22/2006 1:37 AM
Stuart's got it, it's definetly a bad hose. best bet will be to replace all the rubber lines.
Bill Burmeister
#218198 10/22/2006 2:30 AM
You guys seem pretty sure--so I guess I'll have to look into getting new hoses. Any suggestions on where to get them? Thanks for your help.
#218199 10/22/2006 5:09 AM
I just bought all three hoses from NAPA
#218200 10/22/2006 4:05 PM
When I took my front brakes apart, I found rubber from the hoses, inside the fitting on the wheel cylinders.
1951 1 Ton Completed
#218201 10/22/2006 6:15 PM
I agree with replacing the rubber hoses but I have had to remove and clean-out the metal lines as well as clean/rebuild the wheel cylinders in order to get everything working correctly. You can have deteriorating rubber that has clogged other parts and you can have clogged metal lines too. I would start at the master and make sure all hoses and lines are replaced or thoroughly clog-free.
http://www.leonmack.com/
'48 Chevy 1/2 ton
'66 Volvo 122S 2-door
'68 Volvo 220
#218202 10/22/2006 10:37 PM
Thanks for the responses. We are going to replace the rubber hoses, so hopefully that will fix our problem. While we are doing that, is there an easy way to check for clogs in the metal brake lines? Couldn't one make a determination by observing how easily the fluid flows out of the line once we seperate the rubber hoses?
